is a cam worth it? if so, which one?
Old Dec 10, 2012 | 02:22 PM
Izero's Avatar
Izero
Well I did a TC on a GM for my old man like 5 yrs ago... made it hook-up and haul ***... Nice set of tire marks were made effortless....
Down side was snow driving and wet driving when the tires started to wear out... it didn't like to limit the torque output... and sometimes taking off from a stop when it's slippery was tricky b/c it had a higher stall point...
Old Dec 10, 2012 | 02:53 PM
HemiLonestar's Avatar
HemiLonestar
I had my choices down to Circle D 2800 or Edge 2800...Circle D won because I got a helluva discount. Both recommended no more than 2800 stall for me because I still use my truck as a truck, hauling and towing. Big difference. Feels like more power is getting to the back end. Complements the 4.56's nicely and will do well with the 260 I'll eventually get around to putting in.
Old Dec 10, 2012 | 02:59 PM
Ryan Dunbar's Avatar
Ryan Dunbar
what's the upside for such a high stall?
Old Dec 10, 2012 | 04:00 PM
Izero's Avatar
Izero
Read this:
http://www.jegs.com/s/tech-articles/...rque+Converter
It's more suited to racing but it will give you the basics to understand the system.
I think a 280* Cam might be better for Street Use... specially if you're gonna do gears too....
Old Dec 10, 2012 | 10:15 PM
HemiLonestar
Originally Posted by Izero
Read this:
He won't be able to tune it properly...260 is a better all around torque cam.
Not actually all that high. If I had a 2005, could custom tune to my hearts content and didn't tow or anything, I could really throw a cam in like a 273 or something custom with a 3000-3200 rpm stall.
Old Dec 11, 2012 | 09:04 AM
Izero's Avatar
Izero
There are ways around the "tuning" problem.... the only issues he'll run into is the idle control... which really isn't that hard if you have a tuner that allows you to rewrite fuel, timing (A MUST WITH CAMS), and idle tables... downside to a 280* cam is that he'll have to increase the idle a bit so that the minimum lope will be a little higher than the lowest idle speed that would cause a stall.
I'd have to dig into the tables on these trucks to really see what's possible, but I've messed with some pretty difficult cars and trucks before to work around OEM limitations.
Old Dec 11, 2012 | 12:50 PM
SLT8's Avatar
SLT8
273 is retarded so much you can prob' run it on a canned tune. Actually a member on DT ran a 273 on a sc 91 tune. I think it was a hefty 4x4 qc night runner
Old Dec 14, 2012 | 10:05 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I dont think Ive seen any 03s with big long duration cams.
Old Dec 14, 2012 | 05:58 PM
HemiLonestar
Probably didn't run well...or wasn't a 2003
