Surging when started cold
Old 12-11-2012, 09:29 PM
ALW1's Avatar
ALW1
ALW1 is offline
Default Surging when started cold
In the morning when i start my truck it will start fine but within seconds it will usually stumble and almost stall and then recover. I changed the plugs and it got a lot better but not completely.
Also and possibly unrelated when i start the truck in winter it will begin surging (-20c) and will keep doing this even as it warms up. It won't even respond to the throttle. Once i shut it off and restart it, it is fine
Not huge issues but it would be nice to know if anyone else has these issues.
Old 12-11-2012, 09:43 PM
p38251's Avatar
p38251
p38251 is offline
Try throttle body cleaning. Maybe a Seafoam treatment
Old 12-12-2012, 09:35 AM
Izero's Avatar
Izero
Izero is offline
Okay well for us ignorant Americans -20 *C is -4 *F...
At that temperature it is very possible a few things could be happening.
1) Coolant is beginning to Freeze-Up which will cause resistance on the water pump, which causes a shudder/stall condition.
Solution here is to install a block heater and plug it in at night on a timer to warm up at least an hour or so before you usually go out to start the truck, that should help.
2) Oil Weight is too Thick - Consider reducing your oil type down if you're using 5W-20 consider going down to a 0W-20 in the winter months.
3) Dirty Throttle Body
Solution: Clean the TB with Throttle Cleaner
4) Dirty Air Filter
Solution: Replace/Clean Air Filter
Those are the most basic causes, specially at those kinds of temperatures...
Do you have a check engine light by the way? If so give us the DTC(s) from it.
Quick Reply: Surging when started cold
