3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
If you've got 100kmi+ on it, then yeah, I would.
You can buy Fel-Pro seals as a whole package and be cheaper than Mopar price AND get a better quality seal all at the same time.
I agree with dirty. Good preventative maintenance right there.
Literally pry the old ones off with a large flat blade screw driver and tap the new one down flush by using a slightly oversize socket.
Job down in seconds.
Al.
Ahh, didn't know that felpro was better seal. Got them ordered, $25. Yeah the engine has about 83k on it. Since the set is cheap, I might as well go ahead and do it while I'm at it.
Last cam swap I did for a member, when we pulled the heads we changed the seal also. It was as simple as grabbing them with pliers and pulling them off and pushing back on by hand
