Signal light trouble
Old Dec 23, 2012 | 09:48 PM
Bat119's Avatar
Bat119
Default Signal light trouble
2007 Dodge 1500 Laramie
When I turn on my left signal light sometimes the right one comes on instead could this be a relay?
Started once in a while but is becoming more frequent
Old Dec 24, 2012 | 12:25 AM
lyndo's Avatar
lyndo
do a little looking into the multi function switch. This is often the source of these sort of troubles. Since your truck is a 2007 it doesn't use relays, it all goes through the TIPM (totally integrated power module).
Old Dec 24, 2012 | 11:43 AM
mitchn06's Avatar
mitchn06
i have the same problem on my 2005, when on left, right blinks, when on right nothing/ on right blinks several times then nothing, does happen mostly when wipers are on.
Old Dec 24, 2012 | 01:29 PM
66three83's Avatar
66three83
Sounds like your multi-function switch is going bad. Dodge has voluntarily offered to replace faulty switches up to 100,000 miles. You should have received a notice in the mail about a year ago. Since it is a safety issue, you should at least bring it to a dealership, if you are below 100k, they should replace it free of charge. I wouldn't wait too long, because that switch also controls Hi beams and wipers/wash. Not to mention, if you aren't paying attention to the dash, you may just cause an accident.
Old Dec 24, 2012 | 02:00 PM
dirtydog's Avatar
dirtydog
Moderate User
I never recieved anything.
On the other hand, I usually throw everything in the garbage that says Dodge because its generally Solicitation.
Old Dec 24, 2012 | 06:10 PM
Bat119's Avatar
Bat119
Thanks for the heads up on the recall, my trucks at 76 K never received a recall notice I'll take it to the dealer after the holidays
Old Dec 27, 2012 | 07:05 PM
Bat119's Avatar
Bat119
This recall only applies to the 1ton
I asked about mine dealer toldme I was on my own doesn't sound hard to do myself
Disconnect the battery wait 10 mins for air bag to deenergize then pop two covers and remove two screws then replace
Sounds easy have I left anything out?
