Debris above Resistor
Old Jan 7, 2013 | 03:01 PM
bighits4421's Avatar
bighits4421
Default Debris above Resistor
I have a problem with sluggish air in my 2003 Dodge Ram 1500 truck. I tried the resistor a bunch of leaves and debris fell out. And now above it there is a bunch of debris wedged up in there against it looks like a filter, but apparently there is no air cabin filter in these so how do I clean that stuff out and clean the filter looking thing?
(The picture is where I took the resistor out and took a picture up there.)
Old Jan 7, 2013 | 05:30 PM
metaldad's Avatar
metaldad
THAT is NOT a filter.
That is your heater core. For some reason, there is no air filter (that I am aware of) in a ram hvac box. You can attempt to vacuum it out. Use the utmost care because that coil is made from aluminum, and it is a major job to change it.
Old Jan 8, 2013 | 11:55 AM
bighits4421
ok thanks since it is so small I think about getting a air compressor and put it up there and knock all the the debris down so I can use a vacuum.
