Bluetooth for Infinity stereo?
Old Jan 15, 2013 | 01:56 PM
xsdbs's Avatar
xsdbs
My installs date back a few years. Wish these were around back then.
Originally Posted by Izero
I've done hundreds of these installs.... you purchased the wrong harness for it:
Try this website.
http://www.quickconnectproducts.com/...ind.php?id=176
AND READ THE NOTE BELOW THE PICTURE, some Infinity systems have a different harness than others for whatever reason.
You might need to run a wire to an ignition switched power source as well so be prepared for that.
Just in-case you miss the note:
You can PM me if you have any more questions.
As for audio not working but connectivity working, that is usually because it is missing an ignition switched power source or the speaker connection is not 100%.... if you end up with Audio on the wrong speakers it usually means the harness isn't the right one.
