brake squeal
Old Sep 11, 2005 | 05:36 PM
Bigcat's Avatar
Bigcat
Default brake squeal
Hi folks,
As of late my 2004 1500 4x4 brakes have been squealing,I have not pulled the wheels but the rotors look good as best as I can see.
I have heard of others having the same issues but have not heard of a fix?
Any thoughts?
Old Sep 11, 2005 | 05:44 PM
05hemi's Avatar
05hemi
Default RE: brake squeal
You know my brakes are squealing too, and I have an 05 2wd with only 6500 miles on it. I have yet to take the tires off to see what is causing the squeal.
Old Sep 11, 2005 | 07:10 PM
osteodoc08's Avatar
osteodoc08
The most likely culprit is a build up of brake dust. Just get some wheel cleaner and spray it all over the brakes, caliper, etc. Then blast out all of that nasty brake dust with a stream of water. Also, don't spray cold water on hot brakes!
Old Sep 11, 2005 | 08:26 PM
RedSS454's Avatar
RedSS454
Yea my right (pass) front has the squeel. I think I will take a look at that before the snow starts coming. Doesn't really bother me much. As long as it stops, a squeel isn't the worst in the world. Better then the breaks in my Chevelle. They make a right turn for you on their own. I have all teh stuff to fix it (rotors/calipers/bearings/lines) but am just too darn lazy.
Chris
Old Sep 11, 2005 | 09:32 PM
osteodoc08's Avatar
osteodoc08
Depending on the mileage and wear of the brake pads, you don't want a true squeel to go on to long because it will go from a squeel to a grind. The squeel on higher mileage cars is the wear tab letting you know you'll have to change out the pads/rotors soon. But on the low mileage example above, I stay with my initial impression of built up brake dust.
Old Sep 11, 2005 | 09:41 PM
Bigcat's Avatar
Bigcat
I will give the break cleaner a try,I have only 30.000 miles all highway.
Old Sep 11, 2005 | 11:20 PM
Gone Fishin's Avatar
Gone Fishin
Dodges are known for short lived brake pads. They use a softer compound so the "MASS" weight of the vehicle stops better, but it wears the pads out faster. If you opt to replace the pads, I strongly suggest ceramics!!! They stop very well, don't leave much in the way of brake dust, and they don't fade. They are a little rough on rotors though.
Old Sep 11, 2005 | 11:30 PM
osteodoc08's Avatar
osteodoc08
Bigcat, I'd definitely pull the wheels off to see how much pad you have left, b/c as Gone Fishin mentioned, the pads are relatively soft and wear rather quick.
Many here have had good luck with the Akebono ceramics and powerslot rotors. Brembo also makes a plain (not slotted or drilled) rotor for the Rams.
Old Sep 13, 2005 | 10:13 AM
mill500's Avatar
mill500
Same here, only 30k. I didn't think of the dust. I drove it for 6 mos, with almost no dust (guess I'm just getting old) and no squeal. I let my kid have it for 10 days to move, came back with the front wheels full of dust and a squeal at low speed stops when hot.
I'd think Brakleen would work pretty good as well.
Old Sep 13, 2005 | 02:51 PM
osteodoc08's Avatar
osteodoc08
Be careful with the brakleen. Don't get it on your wheels!
When I wash the truck, I spray extra wheel cleaner in and around the brakes. Then as I go to spray them off, I direct a good steady stream of water at the brakes to wash away the accumulated brake dust. Again, don't spray cold water on hot brakes.
