led lights
Old Jan 15, 2013 | 07:54 AM
hopej's Avatar
hopej
Default led lights
I have an 08 ram 1500 st 2wd. My gauges are white with then numbers green tryed led lights from superbriteled but they are a light shade of blue I want them white any suggestions how to do that let me know thanks
Old Jan 15, 2013 | 08:07 AM
GRNDPNDR's Avatar
GRNDPNDR
You will have to remove the actual faces, and scrape the greenish coating off that is covering each number.
That's the only way to make it white because they put a layer of colour on the back so the light shines in that colour.
Old Jan 15, 2013 | 09:59 AM
hopej's Avatar
hopej
Do you know how to do it or a video on you tube that might show how to do it
Old Jan 15, 2013 | 10:06 AM
GRNDPNDR's Avatar
GRNDPNDR
I know how to do it for a Cougar, I can't speak for a Dodge but the process should be similar.
You undertake this at your own risk/expense.
Remove cluster
Using a fork, pull the needles off
Peel off gauge face overlay, may be glued in place so peel carefully and do NOT peel in such a way as to bend or crease the face or it's garbage. Sliding a butter knife or other blunt flat object under it may help.
using a light grit sandpaper (can't remember the number...600+ I think) sand off the colour for each number on the backside.
This should result in a clear/frosted appearance for the numbers allowing your desired colour to shine through.
Old Jan 15, 2013 | 10:13 AM
Izero's Avatar
Izero
They might be blue because of a film coating or they may be blue because you purchased the wrong temperature (color) LED for the job... post a link to which LED you purchased if you don't mind.
Old Jan 15, 2013 | 11:31 AM
GRNDPNDR's Avatar
GRNDPNDR
Oh ya, simplest thing first I guess lol.
White LEDs are actually blue and have a coating/epoxy that makes them white, that's why they usually seem ever so slightly blue.
