help with purchase of transmission 48RE
Old Jan 16, 2013 | 05:09 PM
tomas0042's Avatar
tomas0042
Default help with purchase of transmission 48RE
Hi,
I need advice where I could buy automatic transmission 48RE for my Dodge RAM 2500, 4X4, 2004. I am from Euroupe and I have problems with my serial transmission. My Ram has engine 5.9 Cummins and the power is 650 HP. Please I search a reliable company, which produces this type of transmission. It would be great if the company will be around Miami. Thanks for your tips and sorry for my imperfect english Tomas
Old Jan 17, 2013 | 08:01 AM
Izero's Avatar
Izero
Well Chrysler sells them.... you can purchase from the dealer.... but with 650 HP you are going to need something much stronger than the OEM 48RE.
You can read up on these:
http://www.dieselperformance.com/ind...uct/index/194P
http://www.revmaxconverters.com/inde...d-kit-197.html
Just a suggestion..... If you meant 650 ft-lbs of TORQUE then the stock trans should hold up just fine.
