Transmission slip before shift
Old Jan 18, 2013 | 09:18 PM
badblackram06's Avatar
badblackram06
Unhappy Transmission slip before shift
My 06 Ram 1500 has developed a intermittent slipping issue. It only does it before a shift. It will jump 400-500 rpms before the shift is engaged. This happens a little above 1/4 thorttle. If i'm in the throttle heavy, half throttle or more, the rpms will jump past 4,000 before a shift. I can let off the throttle and the shift will engage.
I checked the codes and got P0932- line pressure sensor circuit.. doesnt tell me if circuit is low or high. I think and hope it may be a bad sensor and its not letting the clutches grab with the right amount of pressure and causing it to slip. But i am no transmission mechanic..
Also, I reset the pcm and tcm by pulling the pcm fuse, putting on my seatbelt and holding the key to run until i heard two chimes. I drove it down the road and back to the house and it seems to shift normal. I checked the codes again and the code did not show up during that drive.
What do you guys think?
Any help would be great!
Old Jan 19, 2013 | 10:22 PM
go-part's Avatar
go-part
Former Vendor
http://engine-codes.com/p0932_dodge.html
You are right, it sounds like the sensor is bad because the transmission will grab the gear if you ease off the throttle.
Old Jan 19, 2013 | 11:14 PM
Chase Lejeune's Avatar
Chase Lejeune
this is probably a little late since ive bought a new truck, but does that go for a 2nd gen as well? because i dealt with that on my old 96 for almost 3 years before i got rid of it, and if it was just a sensor, my jimmies will certainly be rustled.
