03 4 wheel drive
Old Jan 20, 2013 | 01:40 PM
avfd712's Avatar
avfd712
Default 03 4 wheel drive
Does 03 Ram 2500 4wd work off of vacuum and cad actuator or what when put in 4wd the thing makes a grining noise need help?
Old Jan 21, 2013 | 12:35 PM
p38251's Avatar
p38251
floor shifter or switch. switch is vaccum. floor shifter is combo of both
Old Jan 21, 2013 | 12:47 PM
Izero's Avatar
Izero
^ This
Old Jan 21, 2013 | 06:19 PM
avfd712's Avatar
avfd712
Does anyone have any ideals on what would be making the thing make that nosie sounds like some thing not going in all way it will not turn the font wheels. thanks for the input
Old Jan 21, 2013 | 06:40 PM
p38251's Avatar
p38251
poss bad actuator
Old Jan 22, 2013 | 06:19 AM
avfd712's Avatar
avfd712
Thanks. Hey p38251 where would that be at not on front ax like all the other ones i have seen thanks again need all the help I can get is that a bad fix.
Old Jan 22, 2013 | 08:32 AM
p38251's Avatar
p38251
Passanger side axle tube, on the back side. If you have 2 people one person can work the switch. The other can feel and see if the actuator is working. does the 4wd light come on steady or blink? when you try to use 4wd.
Old Jan 22, 2013 | 09:20 AM
Izero's Avatar
Izero
is the 4wd lever on the floor? or is it a dial switch on the dash? We need to know what we're working with first....
Old Jan 22, 2013 | 05:51 PM
avfd712's Avatar
avfd712
I thanks for the help the lever is in the floor. But does not have any thing on axle. I thought it sould have it there to but doesnt. Tha light comes on steady
Old Jan 22, 2013 | 10:15 PM
Izero's Avatar
Izero
the fork that engages the 4wd might be worn and/or not engaging properly. It's hard to tell without seeing and hearing it happen first hand... but that is what I think.
