DIY 9.25 rear end rebuild write up?
Old Jan 25, 2013 | 01:10 PM
richardoutwest's Avatar
richardoutwest
Default DIY 9.25 rear end rebuild write up?
New to the forum, Looking for a write up possibly with pics to rebuild 04 1500 limited slip 3.55 gears rear end. This is the second time it has went out. 1st time at 38,000 the clutch pac went at the dealers coin, $2400 to replace everything. This time it is whining under load and settles out about 65. Thinking they may not have done a true complete rebuild. I now have 124,000. I dont have that kind of cash to to that again or put an auburn or detroit in it.
Any advice or write up would greatly be appreciated!
Old Jan 25, 2013 | 01:52 PM
Izero's Avatar
Izero
well the detroit would be the way I'd go... and I'd pinch pennies and go mad easy on the truck until I could afford it...
There are some videos on youtube but I am not sure if there is a step by step write-up...
Old Jan 25, 2013 | 04:56 PM
Gone Fishin's Avatar
Gone Fishin
Yup-----and get rid of those 3.55 gears. 3.92's at least if not 4.11's. You'll get better mileage, and better all around drivability
Old Jan 25, 2013 | 09:47 PM
lxman1's Avatar
lxman1
Site Moderator
Make sure the pinion nut isn't working loose first.
Old Jan 26, 2013 | 02:31 AM
rought's Avatar
rought
Have you pulled the cover off and looked inside?
Old Jan 26, 2013 | 10:09 AM
richardoutwest
Yes I have pulled the cover, change the gear oil every 30K with Royal Purple, everything looks good, no shavings. Did get water in once but was changed after. i dont like the rubber fill plugs at all. just changed the right bearing and seal. I was going to do both but wanted to do a master rebuild.
Old Jan 26, 2013 | 12:33 PM
lyndo's Avatar
lyndo
if you do want to do it yourself this is about the best write up for a rear end rebuild I have found, not 9.25 specific but its pretty good: clicky
Old Jan 28, 2013 | 09:59 AM
Izero's Avatar
Izero
That is the problem, the royal purple fluid does NOT have the friction additive that our LSD's require to work correctly.
That is what likely helped cause the failure...
Make sure you use the correct fluid called out by the manufacturer of the LSD if you choose an Aftermarket one.
Old Jan 28, 2013 | 08:41 PM
richardoutwest
Thanks a million guys for all the input!
