Dome light wire
Old Jan 29, 2013 | 09:38 PM
KasperR34's Avatar
KasperR34
Default Dome light wire
I'm trying to locate the wire that goes to the main dome light. I'm running welcome leds that will go on and off with the dome light (in turn lighting when unlocked)
I know the wire is yellow with a green stripe. I can only see it in the head liner, but I haven't pulled the A pillar yet, I was hoping to tap into it as low as I can, since the lights are going outside the truck. Anybody know where this wire is located under the dashboard?
Old Jan 30, 2013 | 08:19 AM
Chase Lejeune's Avatar
Chase Lejeune
i think it goes down the passenger side A pillar. so i would assume you could track it from there
Old Jan 30, 2013 | 10:05 AM
Izero's Avatar
Izero
It should go down the passenger side, but sometimes it goes to the map lights/Overhead display and then gets taped up with the rest of the wires and goes out.
You should be able to pry up the dash (the front most part separates from the rest of the dash) and find it in there.
I couldn't tell you where it goes from there though.
I would assume it runs nearly straight down behind the radio and/or glove box then out through one of those grommets to the TIPM/Fuse Box (depending on MY).
Old Jan 30, 2013 | 08:32 PM
GRNDPNDR's Avatar
GRNDPNDR
The wire should run from the dome lights, down the A-pillar and into the cluster. the cluster controls the lights.
Old Jan 31, 2013 | 12:04 AM
KasperR34's Avatar
KasperR34
Thanks guys!
I'll let you know tomorrow, along with some new mods I did today
Old Feb 1, 2013 | 11:25 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Pretty sure its the drivers side A pillar though
