Truck starting issues...please help
Old Feb 3, 2013 | 09:48 PM
matt08ram's Avatar
matt08ram
Default Truck starting issues...please help
hey everyone, im in desperate need of help on finding out what is going on with my truck. Friday my truck wouldnt start, luckily i was at oreilys, and they brought their tester out, and they tested it, the tester came back as dioelectrode in alternator bad, so being in a hurry to get my truck running, i went to the local salvage yard and grabbed an alternator off an identical truck of mine.(2008 dodge ram 1500 4.7l. 4wd), i swapped the two. jumped my truck again, drove all night, all seemed fine. well this morning i woke up, went outside to start my truck.....dead....so i jumped it...and so i thought i would go to oreilys to have them test my battery, and well my truck died on the highway while im driving...i had it towed back to my house. and i jumped my truck again...let it run a good 5mins, then unhooked the positve terminal on my battery to see if perhaps got a bad alternator from the salvage yard...well even after unhooking the postive terminal, my truck still running...and for a good 10-15 mins..so that tells me i dont have a bad alternator...right????....im running out of options of what to do..and i need to get my truck fixed asap. its my wife and i's only way of transportation....what else am i missing...ive checked my grounds...their good..my battery terminals are good...pcm???.......please help..all suggestion will be taken in.
thanks
Old Feb 3, 2013 | 09:52 PM
p38251's Avatar
p38251
You could have a battery draw, draining the battery over night. There is a test for that. I would reccommend NOT pulling the battery terminals off when running, that was the old school way. You can cause a volatge spike a fry PCM or other things.
