06 stock 2500 hemi tail pipe size ??
Old Feb 17, 2013 | 11:15 PM
cyclone429's Avatar
cyclone429
Default 06 stock 2500 hemi tail pipe size ??
Is the oem tail pipe on a 2500 ram 2.5 in? No resonater on the 2500 hemi, Im thinking of running two oem tail pipes instead of having a muffler shop mandrel bend two tail pipes, I can't find a cat back kit were booth tail pipes run out the right rear like a ram SRT 10.
As I cut out the y pipe on the first go arround, I need two tail pipes to replace the crimped and bent pipes that were fabed up to run over the rear axle.
I know the stock dodge tail pipe was mandrel bent..
Walker makes a replacment tail pipe, 2.5 in for a ford dirt cheap and I have found replacement pipes that are mandrel bent for 67 charger, all I need is the bend to cler the rear diff and booth pipes to clear the shock absorber as I will have to cut down the pipe to line up with (mufflers)...
Old Feb 18, 2013 | 11:56 AM
08HEMI1500's Avatar
08HEMI1500
The tail pipe is 3" on the hemi. 2.5 into the muffler and 3 out
Old Feb 18, 2013 | 12:53 PM
cyclone429's Avatar
cyclone429
Thanks... time to get the tape out to see if I can two 3in pipes, between the shock and spare tire. I have two 2.5 in pipes in their now mufflers x2 are going two be 2.5 in.
