03 Dodge Ram Quad Cab - LED Dome/Map Help
Old Feb 27, 2013 | 03:25 AM
bsharp74653's Avatar
bsharp74653
Default 03 Dodge Ram Quad Cab - LED Dome/Map Help
Hi guys and gals....
Basically heres the currently project...
I've ordered the following
http://www.ebay.com/itm/5-PIECE-PACK...item25787c5edf
basicallys its 5 of the 12 LED lights with the 3 different types of adapters... I'm replacing the 2 map lights up front with one led light each should fit perfect and be good to go...
However in the rear dome housing i think I can fit 2 of these.... Im trying to think of the best way tho to setup 2 LED lights in it.. Just splice the wire? or what do you all think would work best?
Old Feb 27, 2013 | 12:25 PM
2008dodgeram1500's Avatar
2008dodgeram1500
i just put these in my 08 but it was vehicle specific and cost me around a 100 bucks there made by putco and got some for my tag light too. Its color is white but it has a slight tint of blue but wow they are bright they also have a lifetime warranty
Old Feb 27, 2013 | 03:05 PM
Izero's Avatar
Izero
IF you splice them make sure you solder and heat shrink the connection...
Personally I'd just make my own board with LEDs and resistors... that's just me though.
They also make complete setups as 2008dodgeram1500 purchased... ultimately it's your call
