%@$#&&% brakes!!!
Old Mar 7, 2013 | 08:03 PM
trz's Avatar
trz
Blacksprot, by the way how do you go about checking to make sure the calipers arent sticking? Just curious for future .
Old Mar 7, 2013 | 11:12 PM
66three83's Avatar
66three83
you would certainly smell it, and if it's front, you would feel the pull to that side.
Old Mar 8, 2013 | 01:44 PM
colbyj1986's Avatar
colbyj1986
I just had this issue with my brake change. I ended up F***ing up the clips for the pads.
Check your rotors and see if that clip is rubbing on the rotor and eating the Diameter up
Old Mar 8, 2013 | 02:41 PM
mike_dmt's Avatar
mike_dmt
To see if you have a sticky rotor, just jack it up and spin the wheel. It should be fairly easy.
Think Wheel of Fortune.... If you spin it and it stops unusually quickly, you might have a caliper dragging.
Old Mar 8, 2013 | 02:52 PM
Izero's Avatar
Izero
lol Not if the parking brake is on... (for the rear wheels anyways)
Old Mar 8, 2013 | 02:56 PM
Blacksport's Avatar
Blacksport
What he said!
Old Mar 8, 2013 | 07:18 PM
Prismatic's Avatar
Prismatic
Also, you can pop the bleeder screw and attempt to compress the piston. It should recess into the caliper housing rather easily. If you encounter much resistance or if the piston refused to move -- it's stuck.
You should always at least have your rotors turned when you change pads. The uneven wear on the old rotor surface will cause subsequent uneven wear on the pad surfaces, which in turn cause more uneven wear back onto the rotor.
Old Mar 11, 2013 | 11:10 AM
Izero's Avatar
Izero
That is more true if you change rotors without changing pads.
But having the rotors turned can decrease their ability to shed heat, so you should always take a micrometer to them to make sure they won't be below the minimum thickness specification in the service manual.
I believe the Haynes and Chilton manuals also list the minimum rotor thickness somewhere too.
Hope this is all solved and your brakes work like new again
