4.56 gears with posi?
Old Mar 20, 2013 | 03:57 PM
jj141979's Avatar
jj141979
Yea. I can't wait too pull the cover and check the wear pattern. The whine starts at about 15mph and and goes away bye 45mph. If I let off the gas the sound goes completly away. I can get the pitch and the way it sounds to change bye touching the gas ever so slightly from 45mph down. It is a very slight noise. Once I get to 50 or 55mph and all the way up to 70mph there is absolutly no whine at all. There is a real high pitched whine pretty much a ring if I'm cruising at 50 or 55mph. After that nothing.
Old Mar 20, 2013 | 03:58 PM
jj141979's Avatar
jj141979
Yea. I can't wait too pull the cover and check the wear pattern. The whine starts at about 15mph and and goes away bye 45mph. If I let off the gas the sound goes completly away. I can get the pitch and the way it sounds to change bye touching the gas ever so slightly from 45mph down. It is a very slight noise. Once I get to 50 or 55mph and all the way up to 70mph there is absolutly no whine at all if I'm accelerating normally. There is a real high pitched whine pretty much a ring sound if I'm cruising at 50 or 55mph. After that nothing.
