need alittle help
Old Mar 27, 2013 | 11:06 AM
tav's Avatar
tav
Default need alittle help
lately there chimes going off along with the lamp out light. when I put my left signal on and brake on..... so I changed my brake bulb that was blown and still does it. i looked all around on the lights and there all good doin what there saposta do. and the blinker still chimes and the lamp out light still goes on. could it be the blinker relay?
Old Mar 27, 2013 | 06:36 PM
lxman1's Avatar
lxman1
Site Moderator
If all of the bulbs are working, it is possibly the circuit board in the tail light assembly.
Old Mar 28, 2013 | 12:58 PM
p38251's Avatar
p38251
did you check the 3rd brake light as well. I mention it because sometimes we forget its there. They gave you the correct bulbs?
Old Mar 28, 2013 | 02:32 PM
Izero's Avatar
Izero
I 2nd the 3rd brake light idea.... also might want to check the blinkers...
If all the bulbs are working then its either the circuit board in the tail light assembly or possibly an issue with the multifunction switch.
