ring and pinion gear help for lift
Old Mar 29, 2013 | 04:21 PM
ram_santos's Avatar
ram_santos
New Member
Exclamation ring and pinion gear help for lift
i would appreciate ur info and feedback.....i am goin to put an 8" lift on my 2007 dodge ram 1500 5.7L 2wd with 22x12 with 35" tires.....i wanted to know how i can figure out the info on my differential and the gears ratio i have.....i wanted to buy 4.56 gears for 9.25" differential and wanted to know if a tune on it would be needed?? thank you
Old Mar 29, 2013 | 07:51 PM
HammerZ71's Avatar
HammerZ71
You really only NEED to recalibrate your speedometer for the tire diameter. Re-gearing needs no adjustment.
A tuner would work quite nicely for this (plus a ton of other benefits) or you can go to your dealer and they can recalibrate the speedo using the Star-Scan tool...
Old Mar 30, 2013 | 02:02 PM
ram_santos's Avatar
ram_santos
New Member
In your opinion what would you choose or which will benefit the overall truck performance??
Old Mar 31, 2013 | 11:27 AM
SLT8's Avatar
SLT8
4.56's or 4.88's. Personally i would do 4.88's to get that lifted heavy barge up and moving.
Old Apr 1, 2013 | 10:55 AM
BigSloth's Avatar
BigSloth
I would go 4.88 as well if theyre available.
Not downing your decision or anything, but I gotta ask.... Why are you lifting a 2wd truck 8"? and why at 8" of lift, only a 35" tire? the stock 275/60/20s measure out to 34.5"
Old Apr 25, 2013 | 02:00 PM
ram_santos's Avatar
ram_santos
New Member
why not lift it 8"?? i mean sure 4x4 are nice but when do u really use it?? if i had a 4X4 i would do the same thing plus i live in south texas and there isnt any hills or anything so i might as well plus im tired of seeing dropped trucks down here so im lifting my truck so it stands out. go big or go home right?? and well i want to put 35" tires so it looks more agressive.
Old Apr 25, 2013 | 02:03 PM
Izero's Avatar
Izero
On an 8" lift the 35" tires will look kinda "small"....
Old Apr 25, 2013 | 02:06 PM
ram_santos's Avatar
ram_santos
New Member
im putting 22" rims tho.....so u think i should go to 38s??
Old Apr 25, 2013 | 02:21 PM
Izero's Avatar
Izero
I think you should go with 20" wheels and 38" tires... but that's my opinion... it's really your call.
an 8" lift is HUGE.... you are going to spend a pretty penny on that one.. lol
Old Apr 25, 2013 | 03:25 PM
ram_santos's Avatar
ram_santos
New Member
yes i know tell me about it lol well the 6" lift im getting is $1,400 and the coil spacers and lift shackles came out to $90 so its kinda good but the the pretty penny is going to the rims and tires lol
