Sway bar link issues
Old Apr 2, 2013 | 09:55 AM
jarred7764's Avatar
jarred7764
Default Sway bar link issues
I have a 2006 dodge ram 1500 4x4. A couple of years ago I put on a two inch leveling kit. Last fall my passenger side swar bar link broke. So I replaced both sides figuring it was just that time. Then a coupl of weeks ago while changing my brakes the same sway bar link was broke. As the truck sits now th tops of both sway bar links are towed in. I am not sure what I can do to fix this. I have the independant suspension on the truck.
Old Apr 3, 2013 | 10:50 AM
p38251's Avatar
p38251
you may need to buy slightly longer links. Check the sway bar bushings. Make sure the sway bar is not in a bind.
Old Apr 5, 2013 | 07:44 AM
jarred7764's Avatar
jarred7764
Where can I find longer sway bar links for this truck. My dad and I have looked at different places and can't seem to find anything.
Old Apr 5, 2013 | 09:12 AM
scwpd's Avatar
scwpd
What type of leveling kit did you put on coil spacer or new torsion keys
Old Apr 8, 2013 | 07:03 AM
jarred7764's Avatar
jarred7764
I have the coil spacers.
Old Apr 8, 2013 | 12:39 PM
Izero's Avatar
Izero
I don't think they make adjustable endlinks for 2006-2008 Dodge Rams....
I know skyjacker makes them for the 2009 Dodge Ram, but not sure if they make them for his year.
They do make some for the 2500 and 3500 which MIGHT work for you...?
http://www.spohn.net/blog/2011/07/27...4x4-2500-3500/
Good Luck
