2005 Dodge Ram 1500 Front Wheel Hub Assembly
Old Apr 3, 2013 | 08:58 AM
Mike Badger's Avatar
Mike Badger
Default 2005 Dodge Ram 1500 Front Wheel Hub Assembly
My wheel/bearing hub assembly is came up lame yesterday. I took the tire off to see what the job entails (my first) on this truck. I am use to seeing a hub nut but the dodge doesn't have one it is just hollow. Other than removing the caliper and brakes, and the three bolts holding the rotor on what do I need to do to separate the hub from the axle?
Old Apr 3, 2013 | 09:29 AM
Mike Badger
Here is a photo of what I am looking at.
Old Apr 3, 2013 | 10:39 AM
p38251's Avatar
p38251
2wd uses some of the same parts as 4wd. Do a search. there are some DIY threads on here to help you out.
Old Apr 3, 2013 | 04:03 PM
Greasy24's Avatar
Greasy24
I just did this yesterday on my 4x4, mine was a little bit harder than yours because the cv axel but you should only have to remove the three bolts and maybe a little wd-40 but it should just come right off.
Old Apr 3, 2013 | 05:55 PM
Mike Badger
Yeah took me a little over an hour this was a lot easier than I thought it was going to be. Not having to deal with the axle was a time saver. Lucky there is plenty of room for an impact to get the job done quick.
