transmission issue?
Old Apr 10, 2013 | 10:09 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Old school here.
Since when did the 4.7 V8 have the 545?
Last I checked they had the 45...
Old Apr 10, 2013 | 10:15 AM
4.7Ram's Avatar
4.7Ram
from what ive herd that was only for the 2002? the after that it got 545, if not and im wrong then that would make everything clear on why it only stays in 3rd
Old Apr 10, 2013 | 11:58 AM
rtmtrrdr's Avatar
rtmtrrdr
I know when I drive in tow/haul mode,no matter how fast I'm going it will not go into overdrive. Any vehicle I have owned did that.
Old Apr 10, 2013 | 12:52 PM
4.7Ram's Avatar
4.7Ram
so on your ram was that 3 gears then? im still unsher of what trans i have...
Old Apr 10, 2013 | 01:02 PM
dodge dude94
I think it changed on 06 now that I think of it.
Old Apr 10, 2013 | 01:08 PM
4.7Ram's Avatar
4.7Ram
so i do have a 5 speed. now i did notce when i put on the trans line booster a year ago, going up hills and what not it would hold 3rd gear forever then shift but it was nice when the OD was on, so im asuming it might be doing the same thing with the OD off?
Old Apr 10, 2013 | 02:36 PM
DodgeCares's Avatar
DodgeCares
Originally Posted by MikeHTally
O/D and tow/haul aren't the same thing. Tow/haul changes the shift points, O/D locks out the over drive gears - it will never go past third gear.
This^^^^^
Question is, how many times are you hitting the button? See below which also can be found in the owners manual on page 309. Link to owners manual below as well.
http://www.ramtrucks.com/en/owners/manuals/
When driving in hilly areas, towing a trailer, carrying a
heavy load, etc., and frequent transmission shifting occurs,
press the “TOW HAUL O/D OFF” button once to
select TOW HAUL. This will improve performance and
reduce the potential for transmission overheating or
failure due to excessive shifting. When operating in
“TOW HAUL” mode, 5th gear (if equipped) is disabled
and 2-3 and 3-4 shift patterns are modified. Shifts into
Overdrive (4th gear) are allowed during steady cruise
(for improved fuel economy) and automatic closedthrottle
downshifts to 3rd gear are performed (for improved
braking) when driving conditions warrant. Pressing
the “TOW HAUL O/D OFF” button a second time to
select O/D OFF will disable 4th and 5th gear completely,
which should eliminate any excessive transmission shifting.
Old Apr 10, 2013 | 03:08 PM
4.7Ram's Avatar
4.7Ram
Originally Posted by DodgeCares
This^^^^^
im hitting the buttom twice, that would explain why it only does 3 gears! thank you DodgeCares, but so whats the point of being able to turn the tow mode and OD drive off?
Old Apr 10, 2013 | 03:20 PM
DodgeCares's Avatar
DodgeCares
Many times it is desirable to have both off when climbing long steep grades, especially when towing.
Old Apr 10, 2013 | 03:28 PM
4.7Ram's Avatar
4.7Ram
cool to know, appreciate the help
