"possible" wierd Superchips problem...
OK A little background...
Got a 05 QC AWD Hemi 20".. Came from factory with a RBQ 6 disk head unit.
During the 1st week (9000 miles ago) I swapped it out for a RAZ CD/Cassette unit. No problems with this swap.
About 3 months ago I installed a XM Direct unit.
http://www.myradiostore.us/xm-radio-...01-chy100.html
Unit has worked fine from install.
Now the problem; Since I flashed the truck with the Flashpaq Tuner (87,6100,140,31.75) I've had a problem with the radio changing volume and stations by itself. Normally I would not expect any type or interaction like this but since this is a PCI controlled truck who knows..
I have not returned the truck to stock yet and prob won't till I speak to Superchips.
The timing of the problem may be purely coincidental. When things occur close together (in time and or space) we tend to assume a connection and sometimes there is not.
Typically, the engine computer has nothing to do with, nor interface with something like the stereo, UNLESS there is a common problem with grounding somewhere. The latter is especially important with computer controlled functions.
Check your grounds and attendent connections to the stereo components first, imho.
Best of luck.
Best of luck.
