check engine light help
Old Apr 16, 2013 | 12:41 AM
edamron's Avatar
edamron
Default check engine light help
Hi guys, so my check engine turned on, i took the truck to autozone to scan it and it said it had a missfire in cylinder # 1. Yesterday I change all the spark plugs also change the coil # 1 for a brand new one, took out the battery to reset the engine light and it turn on again today.
Also i notice white smoke coming out the exaust when i turn on the truck when the motor its cold, when it heats up the white smoke stops.
what else could it be??
Old Apr 16, 2013 | 07:05 AM
MikeHTally's Avatar
MikeHTally
What engine, how many miles? The white smoke is normal as you describe it. It's just condensation. Did you change the plug wires?
Old Apr 16, 2013 | 10:39 AM
edamron's Avatar
edamron
Im sorry. It is a 04 1500 slt 4.7, it dont have wires the plug goes directly in the coil.
Old Apr 16, 2013 | 10:46 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Cracked head maybe?
Old Apr 16, 2013 | 10:51 AM
mp72chall's Avatar
mp72chall
I would get it scanned again. Did autozone give you a printout on the register paper. I used to work at az and alot of those 4.7s would have sensor issues and there are some mistakes at times when looking up scan diagnosis. Make sure you have a good gas cap(computers nowadays will react if a fuel signal is not in parameters) Heres a note for you, autozone did have a policy of taking back any part you buy, so if it doesn't fix the problem ....take the part back. mp
Old Apr 16, 2013 | 11:06 AM
p38251's Avatar
p38251
What plugs did you put in it?
Old Apr 16, 2013 | 11:44 AM
edamron's Avatar
edamron
i used champions
Old Apr 16, 2013 | 11:47 AM
edamron's Avatar
edamron
really didnt knew that... i dodnt remember the code but the print said
cylinder 1 missfire
possible reasons
spark plug
coil
low fuel pressure
injector problem
in that order
Old Apr 16, 2013 | 11:49 AM
edamron's Avatar
edamron
is there a scan that can tell me exacly what it is? do i have to take it to the dealer? and get robbed
Old Apr 16, 2013 | 11:50 AM
edamron's Avatar
edamron
It is a 04 1500 slt 4.7, it dont have wires the plug goes directly in the coil. 108K miles
