wheels and tires
Old Apr 21, 2013 | 09:35 PM
Austin03's Avatar
Austin03
Default wheels and tires
Hey all I have been looking for a new set of wheels and tires but I want them to pop out a little bit past the fender. I have a leveling kit on my truck and found a wheel with a -44 offset I know this is quite a bit but would this be way too much? They have the same wheel with a 0 offset if I wen't with this one would I be able to throw it on a 35" tire or is this tire too big with just a leveling kit? Thanks everyone
Old Apr 22, 2013 | 01:07 AM
jasonw's Avatar
jasonw
Site Moderator
https://dodgeforum.com/forum/dodge-r...s-section.html
Old Apr 22, 2013 | 08:14 AM
04HemiGreg's Avatar
04HemiGreg
Mine have -12mm offset and the tires extend out about an inch and a half. -44 would be too much for my tastes but it really depends on the size tires you are trying to squeeze in there. Mine fit easily with those rims and a leveled front. I could go at least a size larger.
Old Apr 22, 2013 | 10:59 AM
Austin03's Avatar
Austin03
Thanks for the input. I found some wheels with -11 that I was going to go with but then I found the moto metal 962s that I really like but they only come in 0 and -44
Old Apr 22, 2013 | 12:39 PM
04HemiGreg's Avatar
04HemiGreg
Not sure what to tell you other than the -44's will stick out quite a bit and the 0's may not be enough. Figure out what tires you want and read the tire sticky and see if you think you can make it work.
Old Apr 23, 2013 | 12:02 AM
Austin03's Avatar
Austin03
Thanks. I was probably going to order them online but I've been told the 35's won't fit on my truck. But I see people on these forums that say they can run them so I don't know
