02 1500 5.9 Running BAD
Old Apr 25, 2013 | 02:15 PM
Prismatic's Avatar
Prismatic
Does the 5.9 have an IAC? Might be faulty as well.
Old Apr 25, 2013 | 07:06 PM
HammerZ71's Avatar
HammerZ71
My bet is plenum. You can check this by removing the breather, opening the throttle plate and peering down with a flashlight. Any signs of oil and the plenum gasket is hosed. Common issue. Recommended fix - Hughes plenum kit and you'll never have the problem again...
Old Apr 25, 2013 | 07:22 PM
jnellydodge's Avatar
jnellydodge
Yes it does
Old Apr 25, 2013 | 07:26 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Originally Posted by iskifast
OK!! so it wasnt the fuel injector ... although i did have one that was bad... fixing it didnt help.... its almost worse .... wont tack over 2000 now. when I had it on a computer the O2 sensors read fine... I did the sea smoke thing and no smoke came out at all .... And from why this hole thing started from in the firs place replacing the plenum doesnt seem likely ..... next i guess is the cat..
Won't go over 2000 rpm?
Clogged cat. But replace your plenum with the ebay aluminum plenum plate.
Then get you a new cat and NTK 02 sensors, that, in theory, should fix your problem.
Old May 3, 2013 | 03:06 PM
iskifast's Avatar
iskifast
so it wasnt the cat.... replaced the O2 sensor ofter the cat... no change... now its throwing codes P 0031 and 37 also P1296 ... And I've already changed the TBS. again when I put it on the computer last time it said my O2's were fine... and I've already tried resetting the PCM .... I'm pretty sure my plume in ok .. didnt look that bad from the top end..... I no its something stupid .... ???
Old May 3, 2013 | 03:09 PM
Izero's Avatar
Izero
I think it is time to let the dealer look at it... throwing parts at it isn't getting you anywhere.... :-/
Old May 3, 2013 | 03:25 PM
dodge dude94
P0031 means:HO2S heater control circuit low (Bank 1 Sensor 1)
I couldn't find 37...but it also has to do with the 02 sensor heater.
P1296- No 5 volts to MAP Sensor Loss of a 5 volt feed to the MAP sensor has been detected.
And the 02 after the cat doesn't really **** off the PCM unless it just fails. It's the pre-cat 02 that is messed up. If you haven't already, replace that guy with a Denso or NTK.
Old May 3, 2013 | 03:29 PM
Izero's Avatar
Izero
NGK*
Replace the Upstream O2 Sensors, and also might as well replace the MAP sensor too...
If that all doesn't work then you've got something crazy going on!
Old May 3, 2013 | 04:15 PM
dodge dude94
No, not NGK, NTK.
They're made BY NGK.
Same thing.
Old May 3, 2013 | 05:06 PM
iskifast's Avatar
iskifast
Thank you all for all your help..... will deff let ya no what happens .....
