2002 to 1997 2500 cab swap
Old Apr 26, 2013 | 08:46 PM
kevin.smailes's Avatar
kevin.smailes
Default 2002 to 1997 2500 cab swap
Hello,
I am new to this forum.
My son owns a 2002 2500 with the 8ft bed. He wrecked it back in January. Ripped front axle loose. Rolled it into the oil pan put hole in it, broke the differential yoke, bent all the suspension links, busted the transmission bellhousing, tore the starter off, snapped the steering gear shaft, shoved the fenders back, questionable on the right side frame rail near the spring looks bent not sure. He found a 1997 2500 and was wondering if the cab off of his truck would fit on the 1997. Any advice would be helpful.
Thanks.
Old Apr 27, 2013 | 11:50 AM
rtmtrrdr's Avatar
rtmtrrdr
I guess any things possible. It's just how much work you want to do.i think you would better off finding another 02 truck to take parts off
Old Apr 27, 2013 | 05:13 PM
HemiLonestar's Avatar
HemiLonestar
Well...they are the same generation, so it is likely, but I would do a helluva lot of measuring, I think they might have changed a few things in 2000.
Old Apr 27, 2013 | 09:13 PM
MikeHTally's Avatar
MikeHTally
Methinks that will be a nightmare best avoided.
