Last edit by: IB Advertising
Browse all: Electrical Guides
- Dodge Ram 2002-2008: How to Replace Starter
Step by step instructions for the do-it-yourself repairs
New Starter
3.7L / 4.7L
1. Disconnect and isolate negative battery cable.
2. Raise and support vehicle.
8F - 60 STARTING DR/DH
3. Note: If equipped with 4WD and certain transmissions, a support bracket is used between front axle and side of
transmission. Remove 2 support bracket bolts at transmission. Pry support bracket slightly to gain access to
lower starter mounting bolt.
4. Remove 1 bolt and 1 nut if equipped with a manual
transmission.
5. Remove 2 bolts if equipped with an automatic
transmission.
6. Move starter motor towards front of vehicle far enough for nose of starter pinion housing to clear housing. Always
support starter motor during this process, do not let starter motor hang from wire harness.
7. Tilt nose downwards and lower starter motor far enough to access and remove nut that secures battery positive
cable wire harness connector eyelet to solenoid battery terminal stud. Do not let starter motor hang from wire
harness.
8. Remove battery positive cable wire harness connector eyelet from solenoid battery terminal stud.
9. Disconnect battery positive cable wire harness connector from solenoid terminal connector receptacle.
10. Remove starter motor.
5.7L Gas
DR/DH STARTING 8F - 61
4. Remove 2 mounting bolts.
5. Move starter motor towards front of vehicle far
housing. Always support starter motor during this
harness.
6. Tilt nose downwards and lower starter motor far
7. Remove battery positive cable wire harness connector
8. Disconnect battery positive cable wire harness connector
9. Remove starter motor.
transmission.
transmission.
harness.
5.7L Gas
harness.
