Towing equipmend upgrade options
Old Apr 27, 2013 | 10:57 PM
jbird720's Avatar
jbird720
Default Towing equipmend upgrade options
Heres what I have:
2005 Dodge 5.7 2wd w/
Tow package, IE trans., steering, oil cooler.
Rancho 9000 all the way around.
Im upgrading to a bigger travel trailer, keeping within size for my truck.
What if anything can or should I upgrade? Im not getting a new/used Cummins, so scratch that. I have a great truck, and just want to make sure it handles a 30' trailer like a champ.
Old Apr 27, 2013 | 11:03 PM
Chase Lejeune's Avatar
Chase Lejeune
what gear ratio do you have? towing in a hilly area?
Old Apr 27, 2013 | 11:14 PM
jbird720's Avatar
jbird720
Live in Florida but will be taking trips to NC and SC.
Heres what my build sheet lists.
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DMDP 3.55 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
DSA Anti-Spin Differential Rear Axle
Old Apr 27, 2013 | 11:51 PM
04HemiGreg's Avatar
04HemiGreg
What do you have for tires? Are they load rated?
I have towed 30' travel trailers with mine since I got it, with no problems. However I always knew and stayed under my limits. The length is not always a consistent way to gauge weight though. I have seen 30' trailers that weighed between 5 and 6 thousand pounds and I have seen some approach 10k pounds.
Not really anything you can do to your truck to increase towing capacity. Using load rated tires and a decent weight distribution hitch helps with what is within your limits.
Old Apr 28, 2013 | 06:24 AM
Gone Fishin's Avatar
Gone Fishin
2 things I think I would recommend, a load leveling hitch, and a gear swap to at least 3.73 if not 3.92's. The gear swap will help gas mileage as well as help the tranny
Old Apr 28, 2013 | 07:28 AM
jbird720's Avatar
jbird720
definitely not looking to increase tow capacity. I'm running stock 20's with the stock tires.
ill do some research on the gear.
thanks for everyones responses!
Old Apr 28, 2013 | 08:26 AM
04HemiGreg's Avatar
04HemiGreg
Just FYI, the stock p-metric tires on the stock 20 rims reduces towing capacity by around 1000 lbs. And, at least in my owners manual, it doesn't spell that out. I heard a rumor and then called Dodge to verify. You have 2wd though and that gets you back a few hundred lbs over me. I do have 3.92 rear end.
So, if you are looking an upgrade option, in your case, tires would get you more capacity. Mine tows much better now with E rated tires.
Old Apr 28, 2013 | 12:26 PM
Gone Fishin
If spending for a set of gears is not really something you want to consider, an effective re-gear would be to get a set of smaller wheels and go to a smaller diameter tire for towing.
Old Apr 28, 2013 | 01:38 PM
HemiLonestar's Avatar
HemiLonestar
I'd say gear swap and a bigger trans cooler (unless somehow you already have the 3500 version).
Old Apr 28, 2013 | 02:37 PM
TrueDogman's Avatar
TrueDogman
for what its worth......I have pretty much the same truck as yours...except 4 wd and mines an 03. Im hauling about 7500 lbs. 3.73 gear ratio was NOT enough, and I had to go to 4.56. Towing is much better. I haul with od off, and I run about 3000 rpm at 60 mph.
