trans slipping
Old May 12, 2013 | 06:56 PM
popdog's Avatar
popdog
Get a sharadon tranny and call it a day if you're going that route.
Old May 12, 2013 | 09:46 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
You still never told anyone what engine you have, and thusly, we don't know that transmission you have.
But if you want to spend a good amount of money on a trans you never have to worry about again minus routine work, get a PATC trans.
Old May 13, 2013 | 08:32 AM
Izero's Avatar
Izero
Originally Posted by 03dodgeram13
What r ur suggestions when i get a new trans i wanna beef it up for towing. Should i get a new converter and what gears should i go with. I wanna wake it up n make it have better acculeration and torque . More bottom end power .?? Thanx for ur help
We still need to know which Engine you have, as that will dictate your options.
Old May 13, 2013 | 10:08 AM
03dodgeram13's Avatar
03dodgeram13
4.7l n i Dnt wanna spend alot of money. Just want to get it where it needs to be
Old May 13, 2013 | 11:15 AM
Izero's Avatar
Izero
well then have it looked at by a professional so you can find out if it is just the clutches that are worn out in there.... That will save you much more $ than replacing the trans.
Old May 14, 2013 | 07:24 AM
03dodgeram13
I found a trans wit 97k on it for 350$. Dont think i can get it much cheaper .
Old May 14, 2013 | 08:55 AM
Izero's Avatar
Izero
What year is it from?
And remember, you get what you pay for.
Old May 14, 2013 | 12:12 PM
03dodgeram13
Its from n 03. I wanted to no other then check ing the fluid how can i check it to make sure its good ?
Old May 14, 2013 | 01:41 PM
cuda19791's Avatar
cuda19791
If it is already out of the other truck then all you can do is check the fluid and ask for a warranty of some kind. If you are getting it from a junk yard they should offer you a 30 day warranty.
Old May 14, 2013 | 02:31 PM
Izero's Avatar
Izero
+1 on what Cuda said.
If you pull the dip stick and smell it, if it smells like the most horrible rotten eggs you've ever smelled then it's likely been sitting awhile or never had it's fluid changed...
Other than that the only way to know for sure is to flush it with like 3-4 quarts of trans fluid and see what comes out of it, but the true test will only be when it is on the truck and running.
