2007 Ram 1500 true duals
Old May 8, 2013 | 05:19 PM
dougiedododge's Avatar
dougiedododge
Default 2007 Ram 1500 true duals
I am thinking of getting true duals on my truck.I am wanting to cutt the factory y pipe off and just come off of each catalytic converter and go straight back to two Hooker mufflers and exit at the side in front of the rear tire.Does anyone know if this will hurt me as far as back pressure goes or will it be better for me since I have a CAI and Superchips Flashpaq 91 performance tune?By the way,It is a 4.7
Old May 9, 2013 | 10:18 AM
cyclone429's Avatar
cyclone429
if you stay arround 2.5 in for pipe you still have back pressure...stay with the same size as the stock ex manifolds...
removal of the y pipe my require a retap of a a o2 sensor.
Old May 9, 2013 | 10:32 AM
Izero's Avatar
Izero
Inspection might be a problem too... with true duals you still need a Cat on each pipe....
You might end up running into a "lean" condition depending on where the Upstream O2 sensor is placed.
Old May 9, 2013 | 11:22 AM
dougiedododge
My plan is to leave the cats stock as is and cut it right behind the downstream o2 sensor and go from there..But I am wondering if I should put an H pipe in there somewhere or just not connect the two at all?.What would you guys do?H it or not?
Old May 9, 2013 | 12:39 PM
Izero's Avatar
Izero
If you have MDS and do not have it turned off then I'd put an H in there...otherwise it might end up really sounding terrible and raspy... but I don't know what your goal (sound-wise) is...
This video will show you how it might end up... not sure if it's what you are looking for.
Or maybe with an X-Pipe...
There are tons of videos out there, so you can figure out what you are looking for.
Old May 9, 2013 | 07:51 PM
dougiedododge
Thanks for the vids..Im looking for deep and throaty and after reading alot of material..Ive learned that an H pipe will help with that plus balance exaust waves..Im gonna go with the H pipe..Thank you for your input..helps alot!!!
Old May 10, 2013 | 08:44 AM
Izero's Avatar
Izero
No problem. Post pics and videos through the process!
Old May 10, 2013 | 09:26 AM
dougiedododge
Getting it done Saturday the 11th..Ill get pics and vids up after.
