Just added steering wheel radio controls today.
My truck did not have radio controls on the steering wheel so I did some searching and found that they can be added. Turns out it is not that bad to do. I got a steering wheel from a 2002 caravan that had the switches and harness and added two wires made two holes in my steering wheel for the switches and that was it. Have there been any post on this forum about this when I searched I did not find any?
bth_campics362_zps2a588972.jpg?t=1368040148bth_campics361_zpsafaf441c.jpg?t=1368040128bth_campics366_zps524ff357.jpg?t=1368041492
here are 3 pics of the junk yard wheel and the bottom of the clock spring the white connector is the one you have to add 2 wires to the 2 I added are the black and white and red wires.
bth_campics367_zpsb995f04d.jpg?t=1368041520bth_campics369_zpsc16f20ad.jpg?t=1368043957bth_campics370_zps98a15bd2.jpg?t=1368044957
On the white connector the 2 wires you add are pin1 ground and pin2 5volts from the cluster
the gray connector is behind the cluster there are 2 gray connectors you have add a wire to the small one pin12
bth_wiringschematic_zps16d6d761.gif?t=1368120978bth_campics372_zpsf974574c.jpg?t=1368078232bth_campics374_zpsee2437f3.jpg?t=1368078258
As you can see the first hole I made was too big and I broke the switch a little but it still works great. My steering wheel is not in the best shape any way so I will be replacing it at some point.
Yeah it had all of the pins. From what I read all rams use the same clock spring just the harnesses are diffrent. But I could be wrong on that.
lock it down and put it in the how to
