Squeeling From Right Front Tire
Old May 9, 2013 | 11:24 AM
jjsaw5's Avatar
jjsaw5
Default Squeeling From Right Front Tire
Hey Folks,
Recently replaced my brakes and rotors on my 07 1500 Hemi. Shortly after replacing them, there has been a metal on metal squeel/grinding noise coming from my right front tire. The noise is constant and stops if i apply the brakes.
I've taken it to the dealer, they can't find anything wrong. After doing some searches here could it be something as simple as not putting Anit Squeel Compond on the back of the brake pads?
Has anyone else experienced anything like this after replacing brakes and rotors?
Thanks for your time.
Old May 9, 2013 | 07:33 PM
p38251's Avatar
p38251
check the anti rattle clips and backing plate, make sure they are not touching. Disc brake quiet is a good idea.
Old May 9, 2013 | 10:16 PM
colbyj1986's Avatar
colbyj1986
I gave this same problem. The bolt backed out of the caliber and my anti rattle clips are f.ed up. These clips are like 6$ at autozone . easy to fix
Old May 10, 2013 | 06:59 AM
dirtydog's Avatar
dirtydog
Moderate User
You should always use Brake pad Lubricant everywhere the back of the pad touches the caliper. Brake pads vibrate causing the squeal, even the ones with shims. I think shims are a joke and really do nothing other than properly space the pads onto the rotor, so every brake job gets the lubricant! 1 pack per wheel.
http://shop.advanceautoparts.com/web...924%7CL2*15038
or
Check your Rotor shield. It may be bent and touching your rotor, but I agree with the tab issue.
Old May 10, 2013 | 10:53 AM
jjsaw5's Avatar
jjsaw5
Thanks for the responses guys. Planning to address this tomorrow, going to auto zone today to get what i need.
