2005 Ram cylinder block drain plugs?
Old May 27, 2013 | 06:04 PM
Croghanite's Avatar
Croghanite
Default 2005 Ram cylinder block drain plugs?
I'm doing a complete drain, refilling with water, drain again, repeat, etc.
Does anyone have a good pick of where the drain plugs are? Do y'all remove both plugs when you do a complete drain?
Thanks
Old May 27, 2013 | 06:41 PM
Gone Fishin's Avatar
Gone Fishin
They are located on each side of the block at the base of the cylinders. They are a 1/4" pipe fitting. I pulled mine a long time ago and replaced them with petcocks for future drains, which I'm doing this year---actually.
Old May 28, 2013 | 08:45 AM
Croghanite's Avatar
Croghanite
I think I found them. One is very accesible and the other one is hiding behind the starter. Is that right?
The Bolt has a circle on engraved on the head. I noticed the thread sealant. I really don't want to take the starter out to get to the drain on the driver side!!!
Old May 28, 2013 | 03:19 PM
Gone Fishin
The one behind the starter I really can't be sure for you because I have a manual tranny and the starter mount may be a little different. Use a 12 pt sae socket to get on top of the fitting with a ratchet then no fear of stripping it out. Use a good thread sealant when you replace and Do Not overtighten, snug is usually great
