Humm or Agggh on Steering ?
Old May 31, 2013 | 05:35 AM
bigbuck326's Avatar
bigbuck326
Default Humm or Agggh on Steering ?
After I installed new upper and lower and 2 shock struts on my 2006 dodge 1500 4x4 all done . i drove and my hands felt the steering got whooosh humm or arrrgh no vibrated no shake or wobble when 40 mph to 60 mph get worse whooosh.... when make slight turn on left whoooosh and right turn was so quiet what s cause it s possible came from bearing on driving side . two yrs ago i put new hub on right side. or bad steering piston rack ???
thank
cj
Old May 31, 2013 | 05:47 AM
Busdriver9's Avatar
Busdriver9
did you get an alignment?
Old May 31, 2013 | 04:25 PM
bigbuck326's Avatar
bigbuck326
No I didnt yet. Same as you expenience before?
Old May 31, 2013 | 08:16 PM
Busdriver9's Avatar
Busdriver9
I would suggest an alignment by a reputable shop and go from there! it may not be the problem but they will likely find the problem while thy are doing the alignment! just my
Old Jun 2, 2013 | 10:57 PM
rought's Avatar
rought
check the allignment yourself
