07 dies when put into gear
Old May 31, 2013 | 06:45 PM
canadian mole's Avatar
canadian mole
Default 07 dies when put into gear
i have an 07 dodge 5.7 diesel it starts and idles fine but as soon as you put it into drive or reverse it dies like someone shut the truck off any ideas? any moduals that would cause this? it have the factory alarm and a compustar alarm/starter but i do not know how these would cause this.
Thanks
Old May 31, 2013 | 09:11 PM
canadian mole
i just pulled the error codes and i had
2202
2206
1079
128D tcm Power control circuit 2 open this is the one causing the problems i think
Any help?
Old May 31, 2013 | 11:30 PM
canadian mole
So after further investigation the TIPM module had broken off its bolt and fallen off. So is there anything i can do to check this module? any reason why this would cause the error any info would be great thanks
