Efan installed - what do do with exposed clutch fan drive?
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I installed an efan about a year ago and am now noticing surface rust on the exposed fan drive thread. Would like to clean it up and cover with a cap of some sort. Most people probably don't care but these things bother me. Has anybody found a cap to match this thread? McMaster part number would be ideal. Thanks!
What's the good choice for a efan an did you guys run a thermostat or Manuel switch?
The best choices for our trucks are either flex-a-lite 180 Black Max Extreme or Flex-a-lite 183. I believe both of these fans use the same blades and have 3300 cfm and draw 18 amps, but the nicest part is both fit inside the factory cowl, and come with thermostats
