No A/C HELP
Old Jul 2, 2013 | 08:09 AM
tthurston's Avatar
tthurston
Default No A/C HELP
My truck is been acting funny. My blower will only work when the keys are not in the truck as soon as i put them in it shuts off.
Any thoughts?
Old Jul 9, 2013 | 01:31 PM
go-part's Avatar
go-part
Former Vendor
Have you checked your relays and fuses?
Old Jul 12, 2013 | 08:13 AM
tthurston's Avatar
tthurston
all fuses and relays good. new resistor in it as well.
Old Jul 12, 2013 | 11:08 AM
kenneymc's Avatar
kenneymc
So just putting key in the ignition, or putting in and turning?
This is backwards, as you would normally have to put the key in and turn to get power to the blower via the ignition switch. Has anyone done any work to the truck or electrical system lately. I mean anything......if not look at a schematic of the ac system in particular where the ignition is and switched power. Sounds to me like something is shorted right in this area, or possibly something internally wrong in your ignition switch.
Old Jul 12, 2013 | 03:34 PM
Gone Fishin's Avatar
Gone Fishin
Release the steering column, pull keys out so blower runs, move steering column up and down, listen for fan to start and stop running. Its possible you have a wire worn through in the steering column and its grounding out or cross connecting with the blower circuit.
Old Jul 16, 2013 | 09:07 AM
tthurston's Avatar
tthurston
i have looked into all possabilties and still no answers. if i move the wheel up and down it dosent change.
if the key is out the blower runs.
