Different HO cam numbers
Hey Guys..I found a guy saying he has HO cams..But etched in the Cams, the numbers are different then 53021412AD.. An 53021411AD....The numbers hes giving me are 1414AB and 1413C....Do you guys know if these are HO cams?Thankyou..He also said they have a metal lip behind the front journal bearing..The stocks I guess doesn't have this..Any help?
I've searches and searched..An people have asked the same thing with these numbers...The metal lip behind the front journal bearing is the key...So I do believe these are the HO cams...Also would like to ask all the guys running these cams..Have you guys had any issues with using the non HO valve springs?To me atlongs I don't take it up past the factory rev limiter it will be fine..But I don't know..And Im pretty sure that with just my superchips programmer I should be good..I remember reading AirRams post saying superchips and the factory HO cams work well together..An up to 70mm Thortle body..Any disagree?Thanks
Crazy,All these people on here that claim they have HO cams,An not one reply...Is the metal lip behind the front journal area true??I mean the cams don't have either stock or HO part numbers etched into them...
What you should do is find a dealer that has a set in-stock of the known correct part number, go there with your cams and a micrometer and/or caliper and start measuring the lobes of each to compare.
I honestly can't find anything on those part numbers other than people saying they have them and "think" they are HO cams...
Only way to tell is to measure them against the non-HO cams and then compare all the other differences, or you can bring them into a dealer and ask them what's up.
Good luck buddy... We're not going to be able to help you too much more unfortunately
Thanks...I know I searched and came up with the same thing...I bet we read the some stuff...But Nick(AirRam) emailed me back and he said That hes pretty sure They are in fact HO cams..He said he remembers those numbers..And said Chrysler is good for using a bunch of numbers even if its the same part!!!.I don't have the cams or Iwouldn't even have asked..A guy has um for sale over the net...Thanks again for you reply and your time
