3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hi, I have a 2000 dodge ram and I got the air recharged but a couple days later it was gone. I was wondering if it could be the compressor and how could I tell if the compressor is bad???
Ok. I had it at the shop once and they guy put dye in it and told me he didn't see any leaks but the air was only cold for about a couple of days. Is there a way to stop a leak without replacing the whole A/C system?
The leak may be in the evaporator or somewhere else that can't be seen easily. The shop that serviced the system should have documented the pressure and could compare what it is now to when they finished servicing. If it is significantly lower then there would have to be a leak somewhere.
To repair a leak you find it and replace that part not the whole A/C system.
