Cruise only turns on when truck is stopped
Old Jul 14, 2013 | 09:56 PM
Matt5000's Avatar
Matt5000
Default Cruise only turns on when truck is stopped
I have a 2004 5.7. Recently I was driving with my cruise control on. It shut off completely and my engine started to miss. It doesn't do it all of the time, it comes in waves. After it has turned itself I cannot turn it back on. Upon further investigation I realized I can only turn it on while the truck is in park or stopped completely in drive. Possibly. A sensor? Not sure where to start. Any help would be great.
Old Jul 14, 2013 | 11:29 PM
rought's Avatar
rought
Most likely its your front left wheel hub that is bad. The cruise control runs off of that hub. Those are typical signs the cruise control would show if hub was bad..
. http://www.autozone.com/autozone/par..._11892%2C12575
Old Jul 15, 2013 | 12:26 AM
KasperR34's Avatar
KasperR34
Old Jul 15, 2013 | 06:17 PM
Matt5000's Avatar
Matt5000
Would a bad hub cause my engine to miss? I'm assuming there is a sensor in it?
Old Jul 30, 2013 | 06:19 AM
1998dieselman's Avatar
1998dieselman
Originally Posted by KasperR34
THAT IS THE FUNNIEST **** I SEEN ALL DAY
Attached Thumbnails Cruise only turns on when truck is stopped-tumblr_lzv5f0i0pz1qbs6ydo1_500.jpg
Old Jul 30, 2013 | 12:18 PM
p38251's Avatar
p38251
Two seperate issues. As states LF hub assy will fix the cruise. Could be a simple tune up needed to fix the miss. Are you getting any codes for the miss?
