Electrical problems
Old Jul 17, 2013 | 06:59 AM
Frank Lucero's Avatar
Frank Lucero
Default Electrical problems
Ok I need some really good help with my 04 ram 1500 4.7 truck! I am having electrical problems that's causing my lights to dim when I roll down my windows only the master switch on the drivers door works to roll down the windows! I've done the big three upgrade and upgraded my alternator checked the internal workings of my fuse box and no damage inside there! I'm at a loss where else can I look what else could be my problem I would really appreciate any thoughts!
Old Jul 17, 2013 | 03:21 PM
Dodgeboy77's Avatar
Dodgeboy77
i have heard of people having problems with weak batteries. i would definitely take off and clean the posts.
Old Jul 18, 2013 | 02:32 AM
Owensue's Avatar
Owensue
Break in the positive window switch wire in the boot on driver door (by hinges)
My 02 had a break there, there is a connector in the boot, the wire broke right at the crimp.
Good luck.
Old Jul 19, 2013 | 03:49 PM
Frank Lucero
Ok I bought a bigger battery and still the same problems! Now I'm going to check the wiring in the door!
Old Jul 21, 2013 | 10:23 AM
Frank Lucero
Ok update on my truck I have reset the pcm and now my check engine light turned off and so far is staying off! I've tried everything to get that light off and nothing now by reseting the pcm I have solved one of my problems now I just have to work on my windows master switch!
Old Jul 21, 2013 | 10:14 PM
Owensue's Avatar
Owensue
If the issue causing the service engine still exists, it will return.
Check the connector I mentioned, it was where I found my problem with the window switches.
Old Jul 22, 2013 | 11:42 AM
Frank Lucero
Your talking about the connector between the driver door and the dash the one that plugs into the wiring harness on the door? Also yeah the light did come back on but yet I have had new cats put on a new exhaust and all 4 oxygen sensors replaced but it keeps saying o2 sensor bank 2 is out! I've replaced more times than I Carr to count what could be the issue?
Old Jul 22, 2013 | 08:15 PM
Owensue's Avatar
Owensue
There is a connector right in the boot between the door and chassis.
Old Jul 23, 2013 | 11:23 AM
LU229's Avatar
LU229
When you replaced the cat`s, were the new ones OEM cat`s, OEM sensors...?
How long have you been running it with the new cat`s before seeing CEL coming on...?
Explain your "NEW" exhaust system... what exactly did you replace... what brand are the the parts
Old Jul 23, 2013 | 04:01 PM
LVRR's Avatar
LVRR
When anything electrical starts causing dimming when in use it is usually an indication of high current usage, drawing more current than normal.
I would guess the battery as a prime culprit as mentioned above, check to make sure it isn't weak. I would also consider the motor for the window being as old as it is (bad or worn brushes), the switches themselves. Switches can get a carbon buildup from making and breaking contact and take a lot of current to bridge the connection. Check any connector in the system for corrosion of the pins (high current to get by the corrosion). Check the free movement of the windows for dragging in the tracks, gears and bearings. Channels may need some greasing.
I am pretty sure all vehicles nowadays have the voltage regulators built in, but if it has a separate unit you may consider that also.
Just reread your post. You mentioned the master control is the only one working. You will have to go down the chain and check each unit for problems. A high resistance short in any swich on the positive side could also cause your problem. All the wiring comes from and to the master so somewhere along the line could be a problem. Try disconnecting each door in sequence and see if there is any difference.
