Comp 260 Cam 2003 Hemi?
Hi guys, just a quick couple questions for you all with some cam knowledge.
I have a 2003 ram laramie 2wd quad cab with a 5.7l hemi that has been rebuilt after detonating itself when it dropped a valve. From what the shop had told me when they rebuilt it, it had received a new block, all new pistons and rods, and "their" upgraded valve train (including springs). Now that the engine is off its warranty and has proven itself not to blow up again (about 15000 km on it), I want to boost the power a little with an upgraded cam. Currently I have a superchips tuner, CAI, aeroturbine exhaust, and torque management delete (power wire or whatever?) done to it. The goal with the cam upgrade is I want to beat my friends f150 ecoboost from a dead stop, he talks it up so much and I want to shut him up!
Now, questions away. Being that I have a 2003, is the 260 the only "user friendly" option for a cam for this year of truck? Is it the cam that I should be after or is there something else out there? My intent is to run the truck with the superchips canned tune (I am told this is possible with the 260), would I see any real gains going to a custom tune? The plan is to get 6.1 springs and push rods to go along with it, do I need anything else? All install will be at the shop that rebuilt my engine.
I guess I am just looking for some guidance as to what cam would suit my needs and if the 260 is what I should be looking at, if not what. Thanks in advance.
Here is a picture of the truck, cause we all like pics!
I do have the full body kit. I believe it's the same one as on the rumble bees. Thanks for the compliment HemiLonestar, now just sell me your hood!
I have also read up on the sidewinder but I am having a hard time finding where to purchase one. Does anyone have a 260 cam that can vouch for the power increase? Will I be able to beat a 4x4 ecoboost after the install? This is a must haha.
You will get a noticeable power increase, but your limiting factor is the 03 computer (sucks for us). If you combine the cam with 4.56 gears and a good converter you have a much better chance (stacking the deck). Ported heads are a plus, dunno if the PCM can handle BV heads though. How stock is your buddy's ford?
Trending Topics
I was wondering if you ever put the comp 260 in your truck ?
How did it work ? PCM ok ?
thanks
need more.In short, the 260 "worked" running the 03 PCM but it wasn't really happy until I swapped to the 05 stuff.
