Transmission is slipping... What to do?
Thing is, it wasn't known to be a PCM issue. I got the tuner to see if that would square things away. While it has helped, I now know that it was never the source of my troubles... My issue probably stems back to an incident that happened almost two years ago with a mechanic leaving the trans filter loose. I had no way around town so I had to drive the truck (Wasn't known that this was the issue at the time). It was shutting off when stopping too. I drove around for a week low on trans fluid so I believe thats where the issue stems from. Not sure what I should do. I didn't know any better at the time! :P I'm a newb but I looked up what it looks like for a transmission to slip on youtube and found a bunch similar to what my truck is doing, that's why I believe it is slipping. I'm not sure of what the best way to confirm this is.
