need help
Old Aug 15, 2013 | 10:28 AM
hookbender's Avatar
hookbender
Default need help
I have a 2004 dodge ram 1500 with 5.7.just recent the tps light flashes and the truck goes into limp mode.i get it running by getting it moving in limp mode then recycle the key and press on the gas and the truck will start and run fine until i slow down then it goes back to limp mode and i do it all over again.i replaced the throttle body,the apps, installed new fuel pump and changed the transmission filter and screen, none of that has worked.i got no codes i have run out of ideas please help
Old Aug 15, 2013 | 12:01 PM
Welcome to DF! Moving this to the 3rd gen Ram section.
Old Aug 15, 2013 | 05:08 PM
p38251's Avatar
p38251
Did you do the re learn procedure ?
Old Aug 16, 2013 | 11:29 AM
hookbender's Avatar
hookbender
No i haven't i did have my computer flashed though what is the procedure i will give it a shot
Old Aug 16, 2013 | 11:30 AM
hookbender's Avatar
hookbender
Thank you
Old Aug 16, 2013 | 12:19 PM
p38251's Avatar
p38251
There is a thread on here, that will lead you throught it.
Old Aug 16, 2013 | 12:43 PM
Dubl0Vert's Avatar
Dubl0Vert
yeah, do the key cycle, pedal press dealie and that should help. Also, did you do the fuel filter?
Old Aug 16, 2013 | 11:18 PM
hookbender's Avatar
hookbender
I am understanding the filter was built into my fuel pump i should double check that thanks
Old Aug 16, 2013 | 11:24 PM
hookbender's Avatar
hookbender
Is there anyway the fuel injectors could cause this. the thing is sometimes it will run perfect stop and go for about 30 minutes then while sitting at a light the tps light will come on and it goes into limp mode its very frustrating
