2006 Dodge Ram 3500 6sp dies and won't start
Old Aug 21, 2013 | 10:47 PM
dima4855's Avatar
dima4855
Default 2006 Dodge Ram 3500 6sp dies and won't start
I bought a 2006 Dodge Ram3500 cummins, 6sp. As I am driving and hit a bump all the gauge needles died and then the truck died. At that point the security light was flashing and the truck would start for a second and then shut off. We cleaned all the battery cables and made sure they were good, tested the batteries and they were good as well. The only codes I have are:
B210db Battery Voltage Low U0019 Desc unavailable B212DB Ignition Run Only Input Circuit Open C1008C Brake Fluid Level Circuit High C2101C Battery Voltage High C2206C Vehicle Configuration Mismatch U0002 Description Unavailable
I had the stealership make another key and that didn't work, the only thing that works is to press lock and unlock on the key, then get out of the car and lock it with the key and then unlock it. But I don't understand what is happening that this is happening in the first place. Please help.
Old Aug 22, 2013 | 11:40 AM
dima4855's Avatar
dima4855
Bump! To the top
