Help a DIY Female out!
Old Aug 29, 2013 | 08:07 AM
  #31
ewing111's Avatar
ewing111
when i make my umlauts i usually use eggs and cheese, just sayin.
Old Aug 29, 2013 | 08:48 AM
  #32
rtmtrrdr's Avatar
rtmtrrdr
Originally Posted by KasperR34
Which brings me back to my original point. Sell that little fücker, and buy a Hemi.
If they all get about the same gas mileage then what's the point? Since that's the case I'm happier with my 4.7
Old Aug 29, 2013 | 10:39 AM
  #33
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Problem is that the Hemi has almost 100 more HP than the 4.7. And if they all get the same gas mileage, what's the point?
Old Aug 29, 2013 | 01:23 PM
  #34
KasperR34's Avatar
KasperR34
I loled more than I probably should have
As Prince Charles says, spot on, he's got it.
Old Aug 29, 2013 | 08:30 PM
  #35
Prismatic's Avatar
Prismatic
Originally Posted by Izero
Be prepared to spend approximately $10,000 - $15,000 in parts and labor.....
This is a very expensive job... might as well look to replace the truck...
you can score a complete drive train + harness and ecu/pcm/tcm for around $3500.
Old Aug 30, 2013 | 07:44 AM
  #36
MikeHTally's Avatar
MikeHTally
And spend another $3,000 installing it and making it work. Might need heavier front springs. That sounds like spending $6,000-$8,000 on a $3,000 truck.
Old Aug 30, 2013 | 08:46 AM
  #37
Izero's Avatar
Izero
If you do it yourself.... I also think that the trans internals are different on the V6 models but I'm not 100% sure on that one.... I know the 2012-2013 models have different internals for the transmissions on the V6 vs the V8....
Old Aug 30, 2013 | 11:41 AM
  #38
Prismatic's Avatar
Prismatic
$3000 to install? Please. You talking shop price (labor)? This here's a diy forum!
Old Aug 30, 2013 | 11:56 AM
  #39
weedahoe's Avatar
weedahoe
Hall of Fame Member
True. But we're also talking about a females threads here who (no offense here) likely doesn't have an engine lift, engine cradle or tilt, engine stand, air tools and everything else needed.
Old Aug 30, 2013 | 01:31 PM
  #40
Izero's Avatar
Izero
I've seen some kickass ladies in the garage man....so who knows... and yes $3,000 in labor for engine install is about right for a Hemi conversion from a V6....
