need alittle guidance and help
2003 ram 1500
well I think I know the answer but here it goes, maybe there's another solution?
all lights and blinkers work on the truck.... but when I hook up the truck to trailer all works except left blinker.
I did check all fuses with multi meter and all reads 14 v but the trailer fuses read around 7 alternating on the blink, i'm thinking they don't draw much....
am I going in the right direction?
I really don't know how to back track and a bad wire (to much) if there is any, where it T's to the connector and flat 4 there is no connection just tube connections.
do you think it may be a bad blade in the connector? thinking of replacing it.
I'm this close to bringing the truck down to a custom shop that does trailer wires......glenn
all lights and blinkers on the truck work...BUT...when I hook up the trailer all lights and just the right blinker works . left will not work..... yes the trailer.... switched cars and everything works
went to an RV shop and they spliced in a converter to the blinkers to the 7 blade , either that or try and back track a break in the wire and he said that would be insane....so now it works. now I can tow my boat without any tickets...
Trending Topics
I had a broken wire on my factory 4 blade. Lucky it was broken just above where it goes into the loom, otherwise I would have given up as well. It was for my right side blinker/brake light. Those wires back there take a lot of abuse. It would help if the connector was in a different location, instead of under and forward of the bumper. Difficult to reach and as a consequence gets tugged on more than it should.
