06 Mega Cab
Old Sep 14, 2013 | 04:53 PM
Seabeetaji's Avatar
Seabeetaji
Default 06 Mega Cab
Hi, Seabee (seabeetaji) new member here and posted a question on new member thread instead of here but also related to the backseat A/C issue is my fan blower switch was unresponsive so replaced the resister and that didn't work either. But I tapped on the resistor and blower motor came on (had to do 2 more times in last month). Question is: did I get a faulty resistor or is it something else and just an accident it came back on? Guess I'll take it back and exchange since warranty is good.
Old Sep 15, 2013 | 04:45 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Tapping on it could mean a bad part. It could also mean a bad connection somewhere
Old Sep 15, 2013 | 11:52 PM
66three83's Avatar
66three83
There is no separate heat or a/c for the back seat. It is just a duct that is connected to the main plenum in the front. The back seat passengers have no access to heat a/c , or blower speeds. The fact that the vents move up or down has nothing to do with temp, only the direction the wind blows! I would exchange the resistor you purchased if you can, just to eliminate that as an issue. If you still have a problem, it could be your fan switch, or, possibly a problem in your ignition switch. But replace that resistor first, and make sure all connections are tight.
